Fault Codes
timson
has anyone got or seen a difinitive list of fault codes for an Avensis 1.8 VVT-I. Thanks
Hi, timson,
Here are two links that should provide all the OBD1 & OBD2 Code Listings that you will require. =
http://www.troublecodes.net/Toyota/
http://www.obd-codes.com/trouble_codes/toyota/
Good Luck with your Quest, ......... sisavan
