Vibrating Door Locks
yaris_cdx_owner
Hi had my yaris for nearly a year now and one thing (probably the only thing actually) i have found which is really P!&*ing me off is the locks on the door which keep rattling all the time. I have tried putting a bit of sellotape round it but then the door won't lock. does anyone know of any way of sorting this problem out. Don't mind if i have to take door panel off as long as it solves it.
Has anyone else had this problem
Hey there!
Totally agree that this is SO annoying! However their is a solution in the topic below by anemo. Also if you need help getting the doorcards off go to the how-to section and look in the door speaker post.
5th post down
Hope that helps!
i had a similar experience with my yaris.All i did was to carefully open the door covers .After a visual inspection i noted that the wires that connects to the door locks were a bit bent.I straighten them up and the rattling is now very minimal.
I hope this information will solve your problem
I dont have a problem with the rattling door locks, the only problems i have are 1) the interior of the door squeeks wen i open and close the door, and 2) the boot rattles like hell. Fortunatley i play my music quite loud so cant really hear it....
  • 1 year later...
did you try to tighten the screw nail?? try to look where it comes from,,i think theres a one crew nail fall..
