Tyre Pressure
Joel13
Hi all,
quick question whats air pressure should i be putting into my tyres as looking on the side walls they don't tell me.
regards
:thumbsup:
I run 32 front and 30 rear normally as this is good for some nice lift off over steer and is good for long motorway journeys.
30:28 seams best for out right handling tho.
Just make sure you check the pressures regulally with this changing weather as the change in temperature can cause some huge changes in tyre pressures.
i set my tyres when it was cold and wet at 32:30 but then during one of the really hot days they were up to 36:35 ish so try keep an eye on them during the weird temp changes.
Brad =)
Brad =)
Cheers for that Brad will keep an eye on that.
:thumbsup:
My front tyres lose pressure, I think I need them resealed (it isn't a temperature effect).
BTW, you recommended tyre pressures with various weight setups in the car should be written in your glove box for convenience if you forget (or at least it is on the MK. 1 Yari) :thumbsup:
Does it? will have to check that later on.
