I want to connect a pressure gauge to my yaris. I made a conversion with 4efte! Can anyone tell me where to connect the pressure wire?If someone have photos..plz inform me.
Regards
Kostas
from Greece
Regards
Kostas
from Greece
Is the gauge manual or electronic?
This may help with answer. :)
this is not an electronic gauge. It is manual Apexi Boost Gauge. I connected all the wires except the pressure wire. A photo will help me a lot!!
I was thinking oil pressure!.
if its a normal mechanical gauge just plumb into one of your vacuum pipes on the back on the inlet manifold - the MAP sensor pipe for example.
ok. I will put a "T" at the map sensor. This is my car...
my car
Wow, cool swap! B)
