Rav 4 No Instruments Battery Ect But Engine Was Running
papagray
hi
did a stupid thing left lights on called the rac...
boosted the Battery got it started okay, everthing seemed fine hooked up nav system did'nt appear to be lighting up the charge light.. put it down to the rav being intelligent and charging the Battery first drove off..
indicators did not work busy traffic no stopping area.......
then looked at the gauges nothing..
radio nothing windows nothing....
pulled over.. engine still running !
rac recalled
checked every fuse visable... all okay....
had to drive it to a garage with rac as a minder in front
anyone any idea's we suspect the alternator.. as i say we checked the fuses under the hood both sets and inside the car...
:!Removed!:
fault solved
circut board shorted out when recharging from other motor
resoldered running fine now!
fault solved
Just curious, was this caused by the sequence in which you connected the jump leads/booster ?
Cheers,
Dave.
