Hand Brake Adjuster
twentytabs
any know where its located ? .. is it by the hand brake lever or underneath ? cheers in advance
Never done it but think there is a nut with wire coming out of it which is located under centre console by handbrake . Pretty sure you can get to it with an extended socket without having to take console out.
its by the lever, a 10 mm extended socket will do it , take off handbrake first before adjusting it. :yahoo:
nice one lads ... do you just turn the nut and thats it ? or am i missing something ? ...... thanks
6 to 8 clicks is ideal
It will probably have a locknut aswell as the adjuster nut. Remove this before trying to tighten anything up as you dotn want to put too much effort into it and possibly twist/snap the cable.
You can also adjust the rear shoes for a good handbrake :thumbsup:
Mart
