Pinking
Steve
Would you say that an engine that was tuned to take 100 octane fuel would pink if it was used on normal unleaded fuel?
notice when foot was down it pinked a couple of times
ok cool.. thought so
what about octane additives?
assuming ya motors an import then yes any over average RON is ya best bet ie optimax cos it works out the same as using regular juice witht the additives
:thumbsup:
here is some interesting info from TIF forum thanks to Mycroft
Fuel ratings
RON--- MON--- PON
90----- 83------ 86.6
92----- 85------ 88.5
95----- 87------ 91
96----- 88------ 92
98----- 90------ 94
100--- 91.5---- 95.8
105--- 95------ 100
110--- 99------ 104.5
We in the UK use RON others PON
OPT with a (debateable) Oct of 98.6 RON is 95 PON.
SUL with 97 RON is 93 PON
The US use mainly PON
recently on holiday in zante (greek island), i noticed that Shell petrol stations have a fuel called V-POWER which is 99.7 RON.
how come they get near 100 RON fuel and we dont?!!!! grrrrrrrr
so much for standardising europe!
also, i didnt see one damn car worthy of any good fuel whilst out there!
should we petition Shell? just a thought? <_<
another fact by Mycroft
The important thing to remember is that Power is not Octane. Calorific value = Power.
2 examples
Fuel1;
Calorific value gives max power output available at 400hp, but due to its Octane rating of 95RON the max you can get from it is 310hp.
Fuel2
CV gives MPO of 370hp, Octane rating is 110RON the max you can get from it is 340hp
Japanese fuel has a high Octane but has a lower CV than the UK SUL.
The 100oct fuel in Japan is 99.4 to 100.3 MON to be called 100oct it has a CV 4.9% lower than our fuel, to better suit local conditions
The overall effect providing some little change are made to the Spark Plugs, you can run 1 grade cooler (but that is borderline) or open the gap slightly, this is the reason why I found my TT ran better with the 0.9mm gap rather than the 0.8mm as they are in Japan.
***** im gonna have to read that a couple or two more times! :ffs:
:thumbsup:
I always kinda figgured that with people running modern cars that the ecu's would adapt... but then i guess how can a ecu change the timing :D
steve you're wasted here, you need to work for &#33;Removed&#33; NASA! phew!
perhaps at santa pod after a few mind altering substances you could run this fuel rating stuff by me again?! :lol:
