Another Newbie
ace-'rolla
just thought i'd break my toyota ownership duck. bought myself a '95 corolla sportif in white (it was cheap and my poor nova is rusting too fast!)
anyways, hiya!
oh, and how hard are the headunits to change in these cars? cassette players just dont hold street cre these days...
Shouldn't be any problem at all :)
I can't remember if it's fitted with two screws on the sides as in the Corolla E9, however:
If there's screws:
Remove the knobs from the vent-system
Remove the front of the headunit
Unscrew/loosen (what's it called, you probably get my point ;))
Pull the headunit out
No screws:
You'll probably need some tools like two sticks or something like it to put into the sides of your headunit to "unlock" it.
Then pull it back/out
oooh i got mine changed in an L reg rolla
by the big whole at the bottom, to put things there is a screw either side, undo them then pull that whole centre console forward, you will need to pull the heater knobs off aswell, they just slide back on, unclip the connectors for the hazards, heated screen, clock and pull it off, then you will need to unscrew the brakcets on the stereo, pull it out gently and unclip the arial bit and the wires, you will need a new arial adapter £4.99 from Halfords and maybe a harness depending on the unit, only takes about 10 mins to chage iaf
cheers all, removed the headunit tonight, gonna fit mine this weekend. where is the best place to get a half decent but cheap suspension set-up?
