Cracked Rt Fog Light
silverarrow
:angry: :censor: :censor: cracked fog light
HOW much and easy diy any help
looks easy.
Part aftermarket or only from mr t :crybaby:
Any toyota mechanics !!
thanks
update £80 for part and £40 to fit ??
a tiny tiny stone did this in 20 yrs of driving i have never had a cracked fog light
plastic ??? too weak
looks easy.
thanks
I changed my front left fog light last week. To change the fog light you have to remove the plastic cover under the engine (~10 screw/bolts), which is easy DIY. The foglight itself is only fitted with one bolt. I guess you will have to remove the plastic cover to change the light bulb as well, which is kind of bad...
