Lowering
ChrisEC
Hi right im after some advice
ive got a 1.6sr 1999 corolla am i best getting 40mm lowering springs for it or does anyone know if koni do a sports suspension kit for it or any other options that anyone knows about.
thanks 4 any help
thanks 4 any help
Try this site, www.fensport.co.uk its a bit pricy but it is good stuff. I wouldn't drop the front 40mm without changing the front shocks, the rear ones will cope sufficiently with 40mm but you front ones will get very tired very fast.
My setup is fensport springs all round (35mm drop made by blitz in japan) and uprated KYB front shocks, the 20% stiffer ones. You can get some cheap spring kits on eBay but definately watch out for those front shocks.
On my old Corolla I had the Koni shocks front and rear and Apex springs, is an expensive set up but worth it, proper sticks to the road...
