94 Celica Import 2.0 St2o2, 3gse....diagnostic Plug
bounceback
Hi, pretty new to celicas, wanted one for ages, well gt4, but the boss reckoned, i should get to know a 2.0 first.........whatever..............as ever, sometimes its better to go along and keep the piece.........................My help needed bit any wya is as follows.......................................I have noticed the diagnostic plug under the bonnet, have seen oB11 for sale, but the connection plug is different, does anyone know where i can get a connection plug so i can link the car to my laptop..........
most use a paperclip and bridge TE1 and E1 and watch dash for flashes , that represent fault codes .
The trouble codes will appear as flashes of the check engine lamp. Be sure the ignition key is on, the engine off, and your foot off of the accelerator when reading the codes. Two different codes may appear: One-digit and two digit. One digit codes have an approximate 4.5 second delay between flashes with the check engine light illuminating for about a half of a second. Mulitiple codes have a 2.5 second delay between them. For example a code two flashes the check engine lamp two times in a little over one second: I I. If two codes are stored, such as a code two and a code four, the lamp may flash as such: ....I I....I I I I. Crude examples but you get the idea. Two digit codes are similar but will flash the lamp with the first number first and the second number last. An example of a code twleve is I ....II and a code twenty four is I I..IIII.
