Has anyone fitted a band expander in an imported vitz?? Could you tellme how difficult it is and any advice on how to do it?
Thanks!! :help2:
  • 5 months later...
Thanks!! :help2:
I fitted a frequency expander in my imported toyota funcargo (yaris verso). it is only a device that fits between the antenna and the radio. (it is actually fitted behind the radio) simple extract antenna jackplug from radio fit in expander and fit jackplug from expander to radio. finally find a positive line which comes on and off with accessory line and give a positive supply to the expander.
note. The frequency range of the radio is some what smaller than the europen hence only 14 MHZ compared to 20 MHZ. so you have to choose which portion of the band you prefer. I choosed the upper part hence expanded by 20 MHZ.
