hi...new member just got a surf last week... few problems i need help with...... as useuall rear window knackered the motor revolves when taken off but doesnt wind window up ,is it U.S...... ALSO NO REAR FOG THERE IS A ROUND SWITCH near the hard/soft ride switch that has an led on it but it doesnt light up or work any rear fog light that i assume is fitted inside the rear lights, its had a few mots so there must be one. + noisy grinding when i turn a cicle on hard lock 2 wheel drive, sounds like suspension even possibly the rear? couple of bits of laquer peeling is it possible to respray this laquer?any info please
grinding maybe the pitman arm.
fogs are usually 1 of the reversing lights on imports.
Rear window motor can be found in the nearside door of various other Toyota's, try a scrap yard. and the grinding is the steering stops, they should have a nylon cap on the head of the bolt, you can get them from a Toyota stealer or use a big blob of grease on the bolt heads, 4 each side front.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
