Door Speakers Fitting
goologamachuck
I know this has been covered hundreds of times before but all the links are dead! Can someone show me a guide or e-mail one to me (goologamachuck@hotmail.com) for how to fit new front door Speakers on my yaris (reg is 52). Thank you so much! Chris
its pretty simple you just remove standard Speakers and replace with new 17cm ones. if their too deep and catch on the window then make some mdf spacer rings or im sure theres an adaptor you can buy.
There is a triangular bit of plastic in the corner of the door, pop that off, then there are two kinda screw things there get them out, also there are two proper screws in the tray thing in the middle of the dorr and one when you open the handle, give the door a tug from the bottom and it just poppers alls the way around the door from there!
Go to the library and see if they has got a yaris haynes. Or even have a browse in one at your local Halfords lol. As long as it hasn;t got the protective film over it :thumbsup:
yep what he said^^^ :thumbsup:
