Ticking Noise Int He Engine! Help
kularm
Hi guys, another one for you:
Yesterday my oil light was flickering on every 5 mins for like 2 seconds, so i put more oil in after checking the dipstick. However there is a large tapping/banging noise coming from the engine, and when i accelerate it becomes too loud. Secondly, with this ive lost too much power, judging by the speed i can fully accelerate now, it must be 10-12 seconds to 60. Someone help me, my dad reckons my teppets are gone :s whateva they are. Can someone tell me if it is this, what are they, how much is it to repair, and shud i not use the car for a while? cheers dudes and dudettes
How low was the oil, when was the last time you checked it?
If it has been run/driven with low oil for a while it could have damaged/worn plenty of things.
Get a garage to take a look at it and see what they think, no point changing the lifter/tappets if the engine needs to come apart again for more work.
Mart
I do high motorway miles and i had my car serviced 8500 miles ago (60'000 mile service) which was 1 1/2 - 2 months ago. It obv had new oil then, when i checked it there wasnt much in it, but i changed the oil as soon as the light came on :S
Took it to a mates uncle to see, he said one of the cranks might be bust :s how much is a new engine to place and repair. and how much wud an engine be from summit else, say the 1.8 vvti corolla t sport engine
Ones of the cranks might be bust???? Doesnt make much sense really.
Did he say that one of the crank bearings/shells are damaged? If this is the case why not just fit a new big end Shell?
Mart
does the car have a full service record? if so ring Toyota GB you may get something towards a new engine
it does have a service history, however last owner didnt service at mr t, they went to some random place :s is it possible to get some reward back, and also, is it possible like i said to put a more powerful engine in?
Mart
You can never check your engine oil too often. Oil is the lifeblood of your car's engine; sounds like you have bled it dry (poor T Sport) :crybaby:
The engine oil's job is primarily to stop all the metal surfaces in your engine from grinding together and tearing themselves apart from friction.
Is the T Sport an overhead cam? Lack of oil will starve lubrication to the top of your engine.
I would get it assessed professionally by Toyota.
Good luck.
Thats the thing I thought checking once a month was good enough, apparently not :( I loved that car, Was in pristine condition, now its dying on me :( I will rectify the situation, without the need of buying a new car. I will ressurect the T Sport and with it make it better.
