Vtec Celica?!?!?!?
idiorock
hey all, i have just put an apexi induction kit on my car and now it seems that @ 5500rpm the cars engine note gets alot louder and seems to pull alot better, it reminds me of my vti civic i had its just as loud!!! any ideas?
also.... my gen6 202 was broken into recently and the p****s have snapped the centre of my dash and taken the stereo brackets, anywhere i can get another dash insert and stereo brackets cheap, im hopefully selling the car so need to get this sorted. thanks guys
Yeah I noticed this too and it sounds really good with the K&N panel filter and resonator boxes removed! :drool: Almost reminds me of my Corolla T-Sport (with K&N Typhoon induction days)... okay then not quite! :D
thanks for the reply. what does acis stand for??? also i think my cams are worn can i get them reground and can guys give me some rough prices? car just feels sluggish but then i have also had 150mph out of her but noone believes me!!!
Try http://tcbparts.co.uk/ for the bits you're after.
Or just search eBay for "Breaking Celica", "Breaking GT4", "Breaking ST205", etc, etc
There are so many of them being broken you're almost certain to find one within a few miles of home and price of parts you need should be fairly cheap.
ACIS is where you have a valve which opens at a certain RPM allowing more air to enter the intake.
The celica actually doesnt use ACIS, its uses TVIS which stands for Toyota Variable Intake System.
This is a very similar method to ACIS.
On the Celicas you have 8 butterflys. Only 4 are open during normal driving, but once you reach a cetain RPM all 8 open.
Its a great system, but they actually removed it from the ST205 as it became a restriction.
  • 7 months later...
where are these butteflies buddy, mate of mine wants to know, i dont actually have a foggiest what ya going on about but he seems intrigued lol
It depends which celica you have as to whether it runs ACIS or TVIS. This is which has which:
Gen4 GT ST162 & GT4 ST165 have TVIS
Gen5 GT ST182 has ACIS, Gen5 GT4 ST185 has TVIS
Gen6 GT ST202 & GT4 ST205 have ACIS (i think the St205 does anyway, I am unsure)
TVIS = Toyota Variable Induction System, uses a vacum controlled twin port system on the intake manifold.
Each cylinder has 2 ports on the intake manifold, one of the ports for each cylinder is closed at low rpm. At a high rpm the butterflys open up, allowing more flow into the cylinders.
ACIS = Acoustic Control Induction Sysyem, uses a vacum powered butterfly controlled electronically.
This uses a single port per cylinder intake with variable length intake tracts. The intake runners are long when the valve is shut, and at a given rpm the acis valve opens and allows cross port flow, effectively decreasing the intake runners.
What both these systems do is increase torque in the low / mid range and open up for power at high RPM.
HTH
  • 4 months later...
Hi All
Off the back of this topic, I have an ST202 and I suspectt htat the adjustment screw ahs been tampered with.
I was wondering If I removed the head and exposed these, anyone had any expereince with this?
TIA
