Seems A Bit Dead On This Mr2 Side
Holla :yahoo:
Well i thought it seemed abit dead in this side of the forums! :unsure:
So id thought id ask a few questions :rolleyes:
1. Unsure to put some grille mesh in front of the Rad?
2. Boot lid does not stay up no longer, what do i do to solve this?
3. What to do to the rear rev 2 lights if i dont get rev 3 lights in time for Jae?
4. Isit worth putting a cone induction filter on with heat shield or keep my K and N panel filter in stock system?
5. Whats the best brake pads for the n/a?
6. Glove box and paint all peeling off what do i do get a new one from breakers or spray it?
That will do you for now to keep you busy :!Removed!:
but seriously if anyone can help would be great :thumbsup:
cheers
andy
Holla :yahoo:
yo
Yes do it, with black mesh, it keeps the rad form being holed by stones
Buy a new boot spring from Mr T or a breakers
tint them??
IMO, nope, because of heat soak... the k and n panel will do fine... the best thing about an induction filter is the noise though
Carbotech pads from rogue motorsport... standard toyota pads are good too
paint it, infact bring it to JAE and ill paint ot for you, because the propper paint is expensive and I have loads left
nothing keeps me busy :(
cheers
andy
My glove box needs doing also!!
Can you do mine? :P
How much would you charge for that? There'd be plenty of takers!!
Decided to spray the Glovebox myself. Light rub down and de-grease with meths. Used Plasticote (MATT BLACK) - no primer. Three coats. Light rubdown/de-grease. Finished with three coates of Halford clear lacquer. Looks great. Total cost £3.19. (had half a can on lacquer in the garage anyway).
Did you take the glove box off?
The glovebox comes out of the car very easily. The two lower hinge pins just slide out (with a little bit of help). I then masked off the box and plastic release handle leaving only the face visible. I left the Matt Black (B&Q or Homebase) to dry overnight before applying the lacquer. Vey easy - and it makes a significant improvement to the look of the interior.
I'll prob do it when I install the Xbox!
Sounds interesting Gazza.
Have you taken any pics?
(edited to avoid DP)
PS - acstreet> I forgot to say, the only mod I've done is to add mesh to the Radiator grill. I'd definitely recommend it. My rad had obviously been hit quite a few times by stones before I bought the car, and I'm sure the mesh has helped avoid more damage. Pics Here though these are on a Rev 3.
cheers for comments guys
Well just ordered boot hinge as mine has died of a slow death, also finally have painted my brake calipers red,
Now just need to get my grille mesh and then get Dale v to do my glove box lol
cheers
andy
How much was your boot hinge?
Mine went a few weeks ago.
I got the boot hinge for a discount price which was £35.00 brand new as i know someone from a garage in isle of wight where my mum lives, and he gets them ordered from toyota.
If you want me to get you one for JAE i could try and get you one
Andy
Think I'll just get a second hand one.
Cheers anyway!
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
