Which Oils
Jiffy
I need to service my 94 ST205. Can anyone recomend me some oils that i don't need to spend silly money on, i need:
Engine
Gearbox
Transfer box
Diff
Cheers for any advise.
Personally I use Silkolene every time, speak to Guy at Opie Oils http://www.opieoils.co.uk/ he'll sort you out.
Engine Silkolene Pro S 10W50
Gearbox/diff: Silkolene Silktran Syn 5
Not the cheapest stuff but definately the best, put it this way show me another oil that can be put in a rally car engine have the sump crushed and oil drained half way through a stage and still keep the engine in serviceable condition.
The Silktran is perfect for both gearbox/trans/front diff and rear diff, the gearbox/trans and from diff all fill from the gearbox, and you'll need about 7litres in total.
Whatever you end up getting make sure the gearbox oil is GL5 API grade as it's required for the front diff which is feed from the mailbox.
