Wheels And Tyre Sizes
T V O R
Could people post their wheel and tyre sizes for the T2 T3 and T Spirit please, Mk I versions. I’d like to compare rolling radiuses.
Thinking of 195/50/15 for my TS.
:thumbsup:
Just compare them them to your own current size.. work out the difference and then check your own car has the space to accommodate the new tyres, what fits one car may not fit yours depending on modifications etc.
185/55x15 = 292.25mm RR
195/50x15 = 288mm RR
195/45x15 = 278.25mm RR
Assuming you have 185/55x15 now, then 195/50x15 is the best option.....
Difference of -1.45% or -26.7mm (shorter.. note the - .. the sidewall height is very slightly lower.)
So when your speedo reads 70mph, you're actually traveling at 68.99mph
I just want the standard wheel and tyre sizes for the T2 T3 and T Spirit... :thumbsup:
Anyone?
:unsure:
I don't know what dimension does T2 T3 and Tspirit have, all I know is that yaris came as standard with 155/80R13 or 175/65R14 or 185/55R15.
Hope this helps.
It’s something along those lines. Cheers.
Just need the owners of T2’s T3’s and T-Spirits to check their wheel sizes and post them on here.
