A Few Questions
wesifume
Hi again, now the pleasantries are over i'd like to see if i can get some question's answered.
The Key, the central locking key doesn't work, it did, before my Dad sold the car to me! Typical. I don't think its the key's Battery, and he did mention summat about a key dance of some sort, Open the door, stick in the key, leave it for 10 second's, turn it, leave for 10 second's , repeat, and do the hokey cokey! Does anyone know the correct procedure?
Wheel's, although i am happy rolling around on 14's, Yes, Big Pimping I Know! How big/wide can i go?
The headlight's, One alway's seems brighter than the other, do i have an electrical problem.
Thank's in advance. I'm sure I'll think of more. Wes :thumbsup:
try unplugging the big relay in the driver side behine the dash it has a long orange plug on the bottom pull the relay off for 10 seconds then refit . it is about 3x4 inch you may have to slackon right hand lower bolt to remove unit
Thank's Petrolhead. Does the Dash need moving off to get at it, or is it just a bit of a look around?
Right, think i found it. never even knew there was a coin holder in the car, pulled out the coin holder to be greeted by fuses, big orange fuse connecter box above a yellow fuse connecter box,
now, do i give it a pull, or are there clip's involved. Do i try take the whole box off, or remove the wired male part whilst leaving the female part in situ.?
I do not have the most delicat touch when it comes to removing thing's.
Also, only one Battery is working in the key, so i'll change that first before i go near the orange box :thumbsup:
