Kenwood Mp3 Cd Changer
Cobranasha
i have bought a kenwood 10 disc mp3 cd changer to fit to my toyota head unit (w53901) i have the interface that is needed but i am having problems with it
how or what buttons do i need to press to start using the cd changer. e.g if i had a cd in the head unit and i wanted to listen to the cd's in the changer how do i go about it? (the numbers 1-6 to not work so how do i change the selection to the changer)
are mp3 cd changers compatible with none mp3 standard stereos
thanks
sid
thanks
sid
I had a 2003 Corolla with a Sony Xplod Mp3 6 cd changer connected to the original radio. It worked fine an I used the original buttons to switch between cd's. On the radio in de Corolla there was a button called disc and if I pressed it I could switch between de cd player in the radio and the cd changer.
On my kenwood to use the CD multi-changer I just press the "Source" Button. To change CD's I use the FM/AM buttons to switch between CD's.
Not sure if this is the same for all Kenwood's, but that's how mine works. You do know you can download the manual for your headunit from Kenwood don't you? All you need to know is the model number for your headunit.
I just noticed you don't have a kenwood headunit :unsure: .
That'll teach me for not reading the post!
thanks
sid
thanks for that advice just waiting to get a replacement changer because the o-n switch was missing on the first changer which i believe might have restricted the searching mode of the changer to the head unit
got new changer but this one does not have the o-n selector switch. plugged it in and the changer was reading the discs but when i pressed the cd button it would not change to the changer i am getting very very annoyed can someone please help me as this is driving me crazy :blowup: :blowup:
