Induction Kit
mkay99
Hi Guys,
Im interested in putting an induction kit in my p1 t-sport yaris. Any suggestions? What ones have you guys put in? :thumbsup: Cheers..
I've got an A'PEXi. It's a quality item and it sounds amazing! :thumbsup:
get a panel filter mate
no offence to ryan but induction kits are gash to be honest with no real performence benifit
They do have some performance gain if located correctly (responsiveness mainly) and specially with refueling of sorts to match the added air!
yea but most average people just wack it on n go look i have an induction kit lol
ive relocated mine n altho it is better the cars sluggish still, cant put my foot all the way down to the floor cause the engine just dies.was much faster with just my decat.
going to try a panel filter n if that down work im going to relocate to behind the bumper as its in the headlight position now n its still getting warm on hot days
must say it does make your engine look class tho with a massive cone n my lil mini breather filter :) haha
i feel a decat/powerflow/blitz sound clip coming on lol
That's obviously a problem with your car then, I can put my foot all the way down if I feel like it. I've not noticed a performance increase with the A'PEXi but I've got it mainly for the sound. I might get round to moving it to the front of the engine bay one day. :thumbsup:
hi keep putting kit on and take it off still getting very slight flat spot at low revs but it does sound great is it the warmer air ?
not sure mate but it got better wen i moved it to behind the headlight but it still gets dam hot there
also putting a breather filter on made it slightly better
but it make a stupid noise up by red line like a massive rattle
it doesnt pull the whole rev range anymore its struggling after 5000
has a massive flat spot down the bottom end but this is normal for my car jst way worse now ive got the induction kit on
getting an o2 simulator for my decat then its going to toyota to have the engine codes read, fixed n cancelled
fingers crossed it shud fix it if not im screwed lol
also without my induction kit i got 33-35mpg now with it and a decat im gettin 29mpg :|
unplug the crank speed sensor to check if there is oil leaking through the sensor on the bottom of timing chain cover or it could be the vvti controller sticking
Hi have you got a picture of how it looks? and how much did it cost?
that's because it's not tied down and it's hitting your aircon pipes. There will be massive vibrations from the engine at 6000rpm, which will shake your filter like hell.
here's a pic of a relocated apexi, costs about £110-£130 (it usually goes on the end of the standard rubber hose with the 2 90 degree bends on it. If no one else gets a pic i'll post one up.
ive got a blitz sus from fensport cost 130,its easy to fit and sounds nice :thumbsup:
hey i have a power enterprise ind kit and provided to keep it to dry weather this position has had great results as you can see.
Typhhoon or apexi
Doesnt really give you any extra power but gives better throttle response and seems to pull better at high revs!
I have a typhoon and it looks and sounds awesome. I'm not sure if it has affected the performance negatively or positively or not at all. It is located down behin the front bumper area.
Can one of you guys tell me, will my filter be getting enough air down there? There's not really any air flowing directly onto it. Does that matter? Also, if any of you guys have one of these kits, how do you remove it and clean it? I don't particularly want to jack the car up and remove the splash guard like I did when putting it on. It actually looks like I may just be able to unhook it and lift the kit right out. I'm not sure though.
Thanks guys for any response.
