Oil Pressure Switch/sensor 99 Avensis
Graeme
Can anyone tell me where the oil pressure sensor/switch is located on my 1999 Avensis 1.8 SE petrol (7AFE ENGINE)? My oil pressure warning light is coming on at idle when car is warmed up but goes out when I accelerate and I am travelling normally. Dipstick shows oil level fine. Can I drive ok like this? Any help as to the cause would be much appreciated.
The oil pressure switch is on the engine block facing the front of the car. It is on the off-side above the air-con compressor and behind the alternator. About the same height as the oil filter. These engines are normally bullet-proof so hopefully the pressure switch is at fault.
