What Size Speakers Do I Need?
unggy
10cm for the dash Speakers
16.5cm for the door Speakers (17cm may fit with modification)
You'll also need either a custom made door speaker adapter or an autoleads adapter.
17cms do fit into the autoleads adapters without modification (i know this as i have them :P)
Just needs ALOT of spacing though!!!!!
When you say adapter do you mean electrical connector or one of those plastic ring things? Or is it both? And do the dash Speakers not need an adapter?
Dash speaker won't need an adapter. The Door speaker adapters from autoleads include both the plastic ring AND a wiring harness to connect to the original door speaker wiring.
sorry for the replies guys. this autoleads adapters you keep mentioning, i can get it from any car electrical store?
