Squeeky Power Steering Belt Adjuster?
Lusty
I thought I had a slipping fan belt but on the last service I was told it was a worn steering belt adjuster.
Of course you need a special tool to get the !Removed! thing off and of course only main dealer Toyota will have them! :crybaby:
Anyone else with a wining adjuster?
Thanx
If the part you need is the same Adjuster/tensioner i changed for a customer at work yesterday all you need is a couple of 14mm spanners.
I use a lomg straight 14mm laser spanner and a flexi ratchet spanner.
Nothing specialist about this really, just a bit fiddly.
