Recommended Brakes
snellgrove
I had a recommendation to change my front brakes ASAP!
I don't want to replace with standard Toyota parts as I managed to warp & pit my current discs :-)
Anyone have any recommendations or experience with anything a bit better?
I think I'll be getting some Ferodo pads, had a few recommendations about these!
Anyone got any ideas?
I had in my previous 1.3 Yaris Ferodo Premier pads and they were pretty good -- better than stock ones and some people would recommend EBC GreenStuff pads. The choice is yours. :)
depends on how much you want to spend, i've got the endless sss pads, they're expensive at £125 a set but I get no brake dust what so ever, so no really hard scrubbing of the alloys when it comes time to wash the car.
What about discs, are you changing them, you usually end up warping discs because of the heat build up, if you got some grooved one's the heat can escape during braking and less likely to warp the discs.
I have 3g discs and endless pads, and a few have them on here, and i'm sure they would all recommend them.
