Loud Knocking Noise And Lurching Forward Problem.
Old Smokey
I've just registered though I've owned my Hilux 2.4D 4x4 pickup for 2 years now (I love it - the best thing I've ever owned!). The other day it starting making a really bad knocking noise like something had come loose. Then it started lurching every now and then. It seems to be making the noise from the rear axle somewhere and is worse when I'm pulling away and turning. I was told it could be the rear diff or maybe a driveshaft? Can anyone help me?
Thanks in hopeful anticipation...
S :help2:
are you using it in 4x4 mode all the time , has it got a centre diff ?????what year is the surf.
(I've owned my Hilux 2.4D 4x4 pickup for 2 years now )
Sounds like a UJ on the propshaft, have a look under the rear and see if the joint is slack.
Give the prop joints a good fill of grease using a grease gun.
Mart
Normally the UJ's
Do you use it in 4wd much and could you of had it in 4WD on the road giving yourself transmission windup?
Where in cornwall are you, im just outside newquay and could have a look if your really stuck.
  • 5 months later...
hy, i own a hilux year1990 log wheelbase 28disel. a squezing niose comes out loud when reversing and when on enginebreak. i have already renewd the central bearing of the gardenshaft but still same noise. any ideas what might be?
