3sgte (celica - Mr2)
Zipcode
Can anyone tell me if there is any difference between the Late edition MR2 Turbo 3sgte engine and the late model 3sgte Celica gt4 Motor??
I need to buy one for a conversion and just want to know what i am buying or which one is better/more reliable or if they are the same.
Thanks in advace
basic engines and manifolds are the same only the ancillaries (alternator etc and related brackets are different. also the MR2 uses a 4PK auxiliary belt and the GT4 uses a 5PK so the crank pulley would need changing on an MR2 if you use a gt4 alternator etc
