Aldi Fag Lighter 3-socket Adapter
dagbladet
Bought myself one of these as an impulse buy when I was in Aldi Aldi 3 socket adaptor. While I dabble a bit on the mechanical side, I've never really understood Amps, Ohms, Volts etc.
Does anybody know how much juice these things can cope with? There's a fuse in the unit, I assume this will blow before the car fuse goes. If I overload it will I booger my car electrics?
Anybody have any experience with these? :blink:
The fuse in the car SHOULD protect the electrics as a final resort.
Dont quote me on this tho.
the multi adapter may also have a fuse
have a look at you car manual to see what the max you can use
Just plug stuff in! If it pops, too much juice!!
I was running 6 sat navs off one cig lighter socket at work. Albeit, no car fuse, but the cig plug had one and that never blew anyway.
What you trying to plug in? I can't think of anything that'll draw too much.... possibly if you try to plug in 50 travel kettles?
Bibbs tried to run a hair dryer on his old MR2 with an inverter... didnt quite make it!
Another 2004 classic ;)
And hair Straighteners
Puff
Was a good year.
I have bought one of these from Aldi...........£2-99............good value.
The fuse on the plug is rated at 15Amps so should blow before the car fuse if overloaded. Remember that your original ciggy lighter is almost a dead short. (that is why it glows red)
There is a spare fuse included in the pack and the 3 sockets have a seperate switch. The coiled lead is approx 1 metre long (coiled up) so I would expect that to stretch to 2 metres.
Carries a 3 year warranty with a UK address, so all in all a pretty good buy IMO :thumbsup:
Thanks all.
Given that this was an impulse buy, I'm not sure what I intend to run on it but a likely scenario might be Satnav + Phone + Gameboy. If I understand Red Yaris 54 correctly, provided the sum total is below 15 Amps, the fuse won't blow - Correct?
"Remember that your original ciggy lighter is almost a dead short. "
What does this mean mate?
It means that it is virtually the live touching earth to get it to glow red.
Thanks all.
The fuse can still blow, maybe if there is a short in one of the devices
we blew up 5 fuses 1A-5A @ 500V today
