Engine Noise 1.6 Vvti 3zz-fe (2005) From Chile
corolla_sport
Hello guys. My car has a noise but I´m confussed because it has only 42.000 km. Sound likes valve noise but I went to to the dealer for check and they don´t founded anythink.
The dealer check:
Valves ( check gap and adjust)
inyectors
Oil pressure
Compression test
Scaner
So they recommend take of the header and check the valves, spring, and cam shaft
I/m so uggly because i spend a one week waiting a solution or any idea about this problem. This fault is covered by warranty for a while.
I need your opinion
