How To Fix Air Con Leakeg
smily
Water under carpet passenger side is almost certain that block air con.any idea how to fix it.please help.Many thanks
Pull the carpet back from the footwell to access the black rubber drain hose. This will probably be blocked or kinked.
If it is kinked then re route it so it will flow straight. If its blocked find something to flush it out/unblock it with.
Mart
