Tns600 Removal From Hilux ?
webbouk
Hi all, newbie here so please bear with me :thumbsup:
Has anyone any idea how to remove the TNS600 Satellite Navigation unit from a Hilux ?
I'm considering adding a reversing camera to it but need to know if the unit has the required ports on the back of it so that the camera can use the display
Hi Webbouk
If it's in the normal place(centre of dash) then you need to remove the glove box and the panel under the steering column, you may also need to the plastic panel behind the heater sliders.
After these have been removed you should see 4 X 10mm bolts with crosshead slots in, undo these and slide the unit towards you, this then enables you to undo the 2 small bolts on either side of the unit that hold it into the bracket.
I don't think you'll be able to use the unit as a camera monitor as the satnav screen uses a different format for the disply.(although i could be wrong)
Hope this helps.
Cheers
Paul
Hi, Thanks for the reply, the Sat Nav on the new model is located in the midle of the dash between the vents, above the controls, unlike the earlier models
I had a link to an American site showing the fitting of a reversing camera to a unit very similar to this but need to know if this unit has the ports to connect to, the local dealership couldn't advise either
  • 2 months later...
Hi newbie, how did you get on with connecting a reversing camera to the TNS600, was there a video in port, I am also looking at doing the same, so any information would be helpfull.
If its the new shape hilux you dont need to remove the glove box or lower dash.
Just remove the heater knobs and unscrew the centre screw, pull the whole of the heater vent panel off from around the stereo unit and you will have access to the 10mm bolts (x4)
Undo these and pull the unit out.
Mart
if you need to know any more one of the members at www.hpoc.co.uk supplys and fites all sorts of gadgets for the MK6 his user name is invincible.
Thanks for the info Mart and Gupster
Strax, I gave up on the idea not wanting to wreck the dash trying to get the unit out, but now I think I'll give it another go
The Hilux has/is a brilliant machine and perfect as a work vehicle as well as a bit of a toy, the only niggles I have with it is the lack of vision when reversing which has resulted ina couple of tiny dings in the rear bumper from bollards, and the black paintwork as it scratches so easily
Six months of hard use and the only thing that's gone wrong with it resulted in a warranty claim for a new set of alloys as the original ones developed rashes of black 'freckles' under the laquer
The Toyota warranty guy thought it was something to do with cleaning agents until the spare was dropped and it too had a rash of black dots on it
Webouk - I had a Navara before the Hilux it also suffered from a few rear dings, I would like to try and avoid this, the camera would prove very useful, you will have to let me know how you get on.
Strax
