Compressor Irregular Idle And Flashing E.m.l
compressor mad
alrite guys
have any of you compressor owners been sitting at the lights and the car is idleing then starts to hunt between 600rpm and 1100rpm mines done it the otha day :blink:
and also when you jump in my car and turn the ignition on the e.m.l flashes 4 times and goes out
wat does this mean?
cheers lads
The flashing before you start the engine is normal then it should stay light until you start the car, then go out. I think its just the computer performing a self test to make sure that everything is ok.
Not sure about the hunting tho mines never done that.
Mine does the hunting quite often, if i blip the throttle it stops
thats what i done a just blipd it and it stopped :unsure:
cheers tommy for the info on the e.m.l :thumbsup:
