Lambda Sensor
Baby Yari
I know this is a bit of a boring subject and has been bought up a lot of times previous to this, but I need to clarigy before I buy one!!
The cat is the closest to the manifold isn't it and the lamda is housed in there?! Bit of a blonde question but I wanna be 100% sure!!!!
Does anyone know the length of the wire as well, is it the 350mm one??
Thanks in advance!
you have your manifold then your first sensor which sends info bak the the ecu then you have your cat then your second sensor then the centre section
duno about the wire like
There are two, one before cat and one after, the one after cat is 350mm were as one before is shorter i believe!
One of yours gone?!
One of yours gone?!
Well the engine lights on and Toyota said it's likely to be the sensor so I'm trying to source a new one but it's proving !Removed! difficult!! Sometimes I really wish I'd of bought something common like a Corsa! How easy would parts be to find for that!!!?
Toyota said mine was likely to be the sensor changed them both and still had light on, so went to local garage and he took for a drive while plugged into computer and it was because the car was running to cold so changed coolant and hey presto works!
Hope you get it fixed!! dont say the C word!!! lol
