Engine Differences
ace-'rolla
other that a turbo and a bit of pipework, are there any other major differences between these engines? :thumbsup:
yep, the pistons, rods, compression ratios are all different otherwise you could just bolt on a turbo kit. This can be done witha ll the right parts but you have to run far less boost due to the ratios etc
