Electric Windows Stopped Working
bobbarnes
I recently discovered that 3 of the electric windows are not working on my 2003 2.0 D-4D. The weird thing is
that the driver window and sunroof are fine.
My immediate thought was that it would be a blown fuse. So I checked the fuse board under the glove compartment ( nice handy place to put it ). With the aide of the manual I located a type A fuse that was not blown and when removed stopped the drivers window working then a type B fuse that was also not blown and that stopped the sunroof working.
I couldn't see any other fuses that might control the dead windows ...
Any ideas anyone ? The only thing I've had done to the car recently is a new key fob programmed in.
are you serious???
there is a lock button right next to the buttons you use for controlling the window....
probably pushed it by accident...
Thanks for that. Note to self, cut down on binge drinking.
Don't worry I'm sure you're not the first! :thumbsup:
