1. will a toyota previa lucida turbo fit a Toyota Starlet turbo
2. will a toyota corolla gearbox fit into a starlet turbo
my turbo(three so far) has a crack looking for a stronger one (CT9) (all my turbos gain a crack in the exhaust housing and i am a little fed up) and recently my gear box will not go into 5th and reverse and im finding it difficult to find an import gear box. before i rebuild my old one want to know if i could install the corolla gear box with a racing clutch :wacko: .
1. possibly, although I think there is a slight difference in the exhaust housing
2. depends on the corolla. You may need to change bellhousing.
if i got hold of a c56 glanza v gearbox will this fit and could i use the clutch of a c52 starlet turbo ( i just had the starlet clutch installed)
Starlet / Sera / Paseo E-series engined gearboxes are pretty much interchangable.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
