Ecu Reset
Sooty
Hi all,
I've been away a long time.
The other day my engine management light came on.
Does anyone know how to reset the ECU so I can see if it just a blip that turned the light on.
Thanks in advance.
Disconnect the Battery for about 10 minutes... make sure you have a note of any radio codes etc that you need as it will reset the system... or, pull out the ECU fuse from the fusebox.
Many thanks.
Will try that tonite.
