4agze
Sullie..
does anyone know where to get service parts for the 4agze ie: s/c belt and other belts, oil filters ect, other than fensport cant seem to find any companies out there who do
Filter is the same as the one used on the 4a-ge 16 valve.
thanks for reply yes most bits are as its more or les the same engine . s/c belts and others was what i really need at the mo
And 4afe, 3sge, 3sgte and a bunch of others...
How about your local Toyota dealer?!
You'd be surprised how cheap Toyota are for some parts. It helps if you have an EPC with the part numbers though (I'm still looking for one on CD-ROM ;) )
When I recently replaced the HG on our 4AGZE, I got a list of parts off a mate with an EPC and then sourced the bits from Toyota. Timing belt came from MrT as did the timing tensioner pulley, spring, bolts, gaskets etc... Although Drivebelts I went to a local autofactor taking the old belts with for size comparision.
yeah ive been after an epc for ages just cant seem to find one too . in the end i just got the bits from fensport
thanks for the help :thumbsup:
