New Case Is In....
Jamesb4uk
Following on from my heating problems i decided to treat myself to a new case as i felt taht the current one wouldn't help matters.
so i picked up an Antec 900 gaming case :yes:
1 top 200mm TriCool fan with 3-speed switch control
1 rear 120mm TriCool fan with 3-speed switch control
2 front 120mm special black TriCool blue LED fans with 3-speed switch control to cool HDDs
1 side (optional) 120mm fan to cool graphic cards
1 middle (optional) 120mm fan to cool CPU or graphic cards.
coupled with a Front thermal controll unit i picked up at the weekend - should keep it cool :lol:
Will post pics of the case & installed kit later.
J
Good choice.. I have an Antec something or other and it is a good piece of kit with loads of spare bits and pieces!
Cant post pics due to crappybucket being down...
but everythings installed & the fan's are set to low,
pervious temps
Case - 36 Degrees C
CPU 42 Degrees C
Current
Case - 26 Degrees C
CPU - 34 Degrees C
tested in the same conditions using Motherboard Monitor & already there is a masive 10 degree drop in case temp.
J
