St202 Throttle Body
nik tsport blowa!
i eard some one sayin the throttle body off a st202 fit streight on to my t sport, so a got one off eBay and it dont fit, its 4 bolt and mines 3 it doesnt fit to my inlet manifold, plugs arnt same and pipes arnt same, :crybaby:
hahahah i watched that on eBay. i didnt buy it because i was waiting for that guy to be 100% sure it fitted...you obviously didnt think the same and no you`re buggered lol
hahahah i watched that on ebay. i didnt buy it because i was waiting for that guy to be 100% sure it fitted...you obviously didnt think the same and no you`re buggered lol
Charming! Talk about lack of sympathy!!!
:lol:
Stick it back on eBay and see if you can get your money back for it.
I'm sure sticking a bigger throttle body on would have made naff all difference without fitting a larger intlet manifold.
only cost 25 quid so not bothad, and ull see when a make on it ahahahahahahahahahahaha! :P
Stick it back on Ebay and see if you can get your money back for it.
did u get my message i sent u bout ur bonnet mate? :eek:
depends...some tb`s are a smaller diameter than the hole in the inlet where the tb bolts on so it restricts the flow to some extent putting a bigger tb on would get rid of that but i dont know if thats the case with the yaris. could be the same diameter.
my first car had a 40mm opening on the inlet but the tb was 30mm so a guy machined out the standard tb to 40mm and it made quite a bit of difference.
