Alloy Pedals
Templeton
I may be being a bit dim here and missing something blatantly obvious, but I have just bought some new alloy pedals for my car and I'm not sure if they can be fitted.
The pedals I have got are Simoni Z1 if that's of any help. However when I was marking up where to drill, I realised I would be drilling right through the actual lever the pedal is attached to, (hope that makes sense!).
So basically am I going to have to send these back, or am I missing something blatantly obvious?
Over to you folks.
I just moved them to an area where the holes won't go into the lever :)
I did look at that but because of where the holes a postioned on the alloy pedals they would have to be fitted to low down to the existing pedal.
Looks like I'll have to send them back and try and find some more :censor:
i think I had to redrill the extension for my clutch pedal. I suppose if you're bothered what it looks like then thats not the way to go :)
good luck finding some- it could be worth trying some like RAZO ones which clip on instead?
Cheers for that Dan_Q. Just had a look at some of their pedals and it could be a go-er!
good luck :) clip ons could be the answer for you.
another point is, i think I fitted my clutch pedal at the right height but offset to the left from the centre. could be an option too :)
