Another Problem With My Car
Ckman85
hi guys, just drove my car round my cousins place and i hav a REALLY LOUD tapping sound from the engine bay or front wheels, not sure, cud b the drive shaft hitting something. Ever since ive had the car, their seems to b new faults once ive fixed one.
cud n e 1 giv me n e suggestion wot this sound cud b coming from? i most probably need to take it to Mr T again, but also means ill need to take out the induction kit AGAIN!!!!!!!!!!! i dnt think im gna bother fitting it bak on till warranty runs out, its just anoying needing to fit it on and take it out all the time :censor:
Also wud i need to take out my after market wheels incase it is from the wheel area? bcos im sure they wud make n e excuse so ill need to pay
n e help wud b gr8 THANKS
Put her back to standard dont give them any excuse to not get the warranty work done.
Turns out the wheel nuts were loose, so a Relief and Scary in a way, wud of been a ugly site if the wheels came off. my cousin told me the wheel nuts i hav can snap easily, so i didnt put a lot of preasure but still a fare bit of tightening on them. Well thank god it wasnt a major thing. ALL is good again :thumbsup:
i would invest in a torque bar bud
torque them between 90-100nm shouldnt have any problems then
did you put grease on the threads of the studs?
its unusual for the nuts to come loose. are you running oem wheels or aftermarkets?
yeh i was considering buying a torque bar, but cant afford 1 just yet. i will probs use my cousins one next time. Nope im using aftermarket wheel nuts, Rota gave me them as a freebie, bcos they originaly sent me the wrong size tyres
I had that the other day actually... i changed my wheel cos the tyre was worn and needed a replacement (i'm either cornering too fast, or the tracking is off....or it was like that when i got it)... replaced it up and occasionally heard a noise...
got out, checked the wheel and a couple of the nuts were lose... got the wrench out and gave it a bit more force... still checking it every day just to make sure.
