Boost Controller
yellgt4
i have got a boost controller. so it says on the box its not a bleed valve. dunno what the difference is.
any ways, i figure it should be fitted in the pipe that goes between the turbo and the actuator, but there is another pipe that leaves the actuator. If i is right in thinking this goes to the boost pressure sensor, wont fitting the boost controller cause problems. Do i have to disconnect the other pipe. is it even worth while fitting the boost controller. any pros and cons. dunno enough about turbos to fiddle too much, but was told it was a simple mod by the geyser who sold it to me :censor:
Has anyone had any probs with these things
thx in advance
:unsure:
