Sorry if this is in the wrong place - I'm new to the forum.
I urgently need a road speed sensor for a 1995 Hiace Super Custom Auto. Does anyone know where I can get one from without going to Japan???
I'm not botherered if it is new or used but it is urgently required, as the speedo will not work without it.
Many thanks
Zakstaff
any toyota dealer will supply what you need.
Have tried dealers but according to them, the part is no longer listed!! Does anyone know whether the same part is used on the Granvia or Regius model?
I'll be grateful for any help or advice asap. We need to use the car to tow a caravan for holiday next weekend, so it is now very urgently needed
  • 4 months later...
is it the cable version or the electronic version.check the transfer casing ,kneel down at the drivers doors and look under,it should be there.if it is stiff its the cable and if there are 2 wires,its the electronic.
the electronic ones are found on hiluxs and hilux surfs as well as previa,estimas and all that
if you find 2 let me know i can't get one yet.
