Corolla Ae86
ShamGTTurbo
Hey all, recently bought a corolla ae86 gt apex.
My friend was checking it out and said its got a blue top engine in it.
What is the differences with the blue top and the standard 1?
All info needed...
4AGE Type's
- Very early big port TVIS 16 valve, with black lettering & 6-bolts holding the flywheel on.
- Big port TVIS FWD/RWD 16 valve, usually with blue lettering on the cam cover and 'TVIS' on the inlet plenum.
- Big port TVIS FWD 16 valve, with red lettering. They have a seven-rib block with oil-squirters.
- Small port non-TVIS FWD valve.
- Silvertop 20 valve. Early & late type, minor variations in inlet system & VVT operation.
- Blacktop 20 valve.
- Early supercharged 4AGZE, low compression big port head, distributor.
- Mid-aged supercharged 4AGZE, higher compression big port head, crank angle sensor type ignition.
- Late supercharged 4AGZE, higher compression small port head, crank angle sensor type ignition.
More information on these engines below.
http://www.billzilla.org/4agstock.htm
Very handy site and should answer all your questions
