Squealing Brakes
michael0708
i know the pads will need changing, this is my first toyota, are parts easy to come by ( namely pads ) any special tools required to change the pads, anything i need to watch out .
one last question anyone recommend an online store to purchase parts from
thanks in advance michael
2.0 r plate avenisis 98 gls
HI MICHAEL,
PADS FOR YOUR CAR ARE AVAILABLE FROM MOST MOTOR FACTORS OR CAR SUPERSTORE OFF THE SHELF
IT IS AN EASY JOB TO DO EVEN IF YOU DONT HAVE ANY MECHANICAL EXPERIENCE
YOU WILL NEED A 7MM ALLEN KEY,FLAT HEAD SCREWDRIVER AND A BIG GRIPS (TO PUSH THE CALIPER PISTON IN)
REMOVE THE TWO 7MM ALLEN KEY BOLTS FROM THE BACK OF THE CALIPER AND REMOVE THE BIG SPRING CLIP AT THE FRONT,CALIPER WILL NOW COME AWAY FROM THE PADS,REPLACE PADS AND SQUEEZE THE CALIPER PISTON BACK IN WITH THE GRIPS,DO THIS SLOWLY AND REMOVE THE BRAKE FLUID RESEVOIR CAP FIRST.
PLACE THE CALIPER BACK INTO POSITION AND LOCATE THE SPRING CLIP AND BOLTS AT THE REAR,TIGHTEN BOLTS AND YOUR DONE!
MIGHT BE A GOOD IDEA TO APPLY SOME COPPER GREASE TO THE REAR OF THE PAD WHEN YOUR REPLACING THEM
(STOPS THEM SQUEALING!!)
HOPE THIS HELPS
JAYK
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
