Colour Code
zetor
Hi, my Corolla is a 2006 D4D (E12) and I am having a problem locating the colour code so I can buy some touch up paint, the car is left hand drive and the log book colour says "Gris", Grey to you and me:) I believe the the brochure mentioned it being "Storm Grey" but where is the code located? I found the VIN number at the rear of the engine but no code there, the only other info I found is on a sticker in the inside drivers door but not sure if any of the numbers were relevant to a colour code or not, any idea's most welcome, thanks.
Zetor
Zetor
There must be a sticker or so with several numbers or codes on it.
Your colorcode has to start with a 1 and has 3 digits. ´Storm Grey´ has the colorcode 1F6 here in the Netherlands.
Zetor
From the sticker code inside the drivers door it would seem to be 1C3 but from http://ourworld.compuserve.com/homepages/stepho/colour.htm it says that it is Riverock Green, I can check to see if the local car shop has 1F6 and see if it is what I need, thanks.
Zetor
