Avensis 1.8vvti Abs Light (new Discs + Pads)
rads
Hi all,
I have just renewed the rear discs + pads and the front brake pads on my 2002 toyota avenis. Since I have done this the ABS light on the dash has come on. Has anyone got any idea's as to how to turn this light off or what the fault might be. When doing the disks + pads I did not interfere with the sensors at all. Mnay Thanks.
Whip it in to your local dealer to get the code read, you may have a sensor gone down, not uncommon, they can reset the light for you too Kingo :thumbsup:
Thanks mate, everything was fine before i did the work. I was just wondering if there was a reset procedure i could carry out before i had to visit the stealers.
Ooooh, stealers, lol, a lot of dealers wont charge you to find what the code is (we dont) providing you either have the job done or buy the part from us. ABS sensor is the most likely cause, I have seen procedures on here to cancel the code yourself, but can't tell you if they work or not. Kingo :thumbsup:
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
