Vibrating Toyota Avensis
zaf50
Hi guys recently got my avensis on the road and drove for about 700 miles since has been parked on my drive surplus to requirements.
Now especially during bends car wheels vibrates can feel the vibration in my legs steering seems fine no tremor not puling to one side.
Should I get the wheel tracking and balancing sorting or could it be warped brake discs?
Also can someone explain has to what is the MAF?
VERY MUCH OBLIGED
THANKS GUYS
I think the things to check are as you say wheel alignment (this should be done free of charge only paying if it needs adjusting),wheel balance and check your tyres have not gone out of shape through sitting on your drive stationary for some time
I think a MAF is a Mass Air Flow sensor (The Air Flow Sensor or Mass Airflow Sensor (MAF) is one of the components of an electronic fuel injection system and is found in many of modern vehicles. )
Taken from google
Problems with Mass Air Flow sensors are common. Bad or contaminated Mass Air Flow sensor can possibly cause a wide range of various vehicle driveability problems such as stalling, especially when the engine is cold, misfiring, poor acceleration, etc.
